Took the right front wheel off to put on new brake pads, once the wheel was off, i turned the hub, it was tough to get to turn and then notchy. Is it the way the differential is made that if you turn that wheel it is tought to turn and notchy? The left front is very smooth. I hope its just the way the gears are that give it the notchy feeling while turning it.
was the left wheel off the ground at the same time? if so, you may need a RH axle- it should be smooth like the LH was. it might drag some cuz you're turning the gears, but it should be smooth.
Like on a FWD car, when the CV joints start to go in the axle they make grinding or popping noises when you turn the wheels right or left. may not be noticeable when going straight.
My Accord goes 'clunk clunk clunk' when I turn left sharply- the warning sounds of an axle going out. Quads are no different.:aargh:
    • By TomJulio
    • By vaneleus
    • By TomJulio
    • By Olchap
      Thank you,
      Olchap
    • By BillR94
      Thank you for your time
      Bill
