1998 Honda Recon valve adjustment HELP!!
By gordonmacritchie
all fuses are fine
By Admin
By toe420
By TomJulio
I recently noticed my Fourtrax 2WD has 4WD wheels installed on the front. The back spacing is significantly different than 2WD wheels and they are almost touching the strut springs and the tires actually do touch the springs.. So far, no luck locating 2WD wheels to correct this issue.
