By opnea
Recently picked up a 1991 Lt230e for repair. Compression is a little low Id say, around 80psi, I also have spark but the spark is odd . When cranking the spark is a constant arc. I’ve got it to sputter but never fully turn on. I believe the spark is my issue, being constant and not detonating at the right time. I’m not sure whether this issue is an electrical fault like some missing ground, a faulty cdi, or a timing issue. Any ideas where I should start?
By p5200
I'm having trouble identifying Mark. I know where the mark is in the Stator cover. Is the T at about, the 12 o'clock position in this photo? I've got to buy another Stator cover as the one I have has a hole at the bottom of it. Due to failing eyes, I have a lot of trouble anymore. Thanks! 🙂
By mga
I just want to clarify that i was doing the timing correct. I wanted to adjust the valves, so, I removed the spark plug, I removed that little black plastic cap on the side, then, i turned the engine counterclockwise until the "T" lined up with the small groove on the threads where that black cap screws in. Then i checked the valve clearances.
So, what is the "F" mark for?
I hope the "T" was the right mark to use. lol
By huntindog
TIA
By dvs1961
Similar Tagged Forum Content
- 1 reply
- 3,063 views
- 4 replies
- 3,216 views
- 1 reply
- 3,175 views
- 23 replies
- 3,217 views
- 6 replies
- 3,393 views
