New Spring Specials!!
By DPDISXR4Ti
Thanks...
By Kawiherder
So I'm out in the woods using the ATV and I notice a gas smell. Turns out the gas was running out the nipple on the very bottom of the carb. I suspect the float must be stuck so I tap it a few times but the gas is still running out. It flooded the engine and killed it. Any bets on a few more taps freeing it up or will I need to pull it out?
By MarkinAR
Have any of you fine folks used coil spring spacers to lift an ATV? Ole 93 Kodiak could use a smidge more lift and they are cheap enough. Might ride rough but that's ok cuz the shocks are toast anyway.
Thoughts?
By LMI
Hey all,
It's been a while since I posted. Fan trouble and the replacement I sourced on amazon is still working great on my 2005 Suzuki KQ700.
Unfortunately this year I lost my outdoor best friend. He's that go to guy for everything … the day run, may walleye opener, last minute hey my boat's at work get your a$$ over here with your rod and let's go kinda buddy. I bought the quad last year in March and with him gave it the once over and prepped it for fall hunting season, but cancer took him before we could enjoy this new aspect of outdoor life. We planned an October trip into the bush with our quads guns and tent trailer. It never happened. A tribute to our fallen and lost.... But in their memory take the opportunity to grasp every minute of the outdoors you can, life is short... you can sleep at the end...
I've curious what everyone has been doing to prep for the spring season. I mounted my battery and the quad started up straight and easy, just powered it up once or twice to juice the injectors and it fired up after a couple of seconds. I let it run, confirmed fan started, checked charge voltage. all good. I did all my oils in the fall to make sure no water was present anywhere so skipped that this spring.
So what have I done over the winter to prep for quadding? I've been researching. This year I am going to cross over quading with brook trout fishing. So I have been pouring over my old maps from my youth, google maps... looking for those faint markings of trails I can't travel in my F150 (well not yet, paint still looks pretty good ).
By Chad Hjortshoj
Hey, working on my gf's lil dvx250 which needed the carb cleaned. Like an idiot I removed the bracket that holds the choke lever on and the spring that was behind it that I hadn't seen popped off. Anyone have a clue how it goes back on? The manual pics dont show it and I had no luck on YouTube! Thanks!
