By HSTAR
By Suzukiquad
By ResQ91
Hi guys
battery and connections good
By Bobbywolf
Thanks for any assistance.
By mga
I just want to clarify that i was doing the timing correct. I wanted to adjust the valves, so, I removed the spark plug, I removed that little black plastic cap on the side, then, i turned the engine counterclockwise until the "T" lined up with the small groove on the threads where that black cap screws in. Then i checked the valve clearances.
So, what is the "F" mark for?
I hope the "T" was the right mark to use. lol
Similar Tagged Forum Content
- 0 replies
- 1,454 views
- 0 replies
- 1,478 views
- 1 reply
- 2,808 views
- 0 replies
- 1,502 views
- 8 replies
- 3,318 views
