Similar Topics
By starsteven22
Anyone have a problem with the Polaris instrument cluster/speedometer frozen(part # 3280453) ? Mine is always showing R and slow now(see photo), Did it go bad or can you reset it or is something else the problem. It is on a 2004 Sportsman 500
By mga
I have to replace all 4, how much is involved? Will they slide out of the front yoke? Or, do the boots just slide over the wheel end?
By Params_sweden
Hi!
I got my KLF300 running again with your help a couple of months ago, at that time it was the ignition coil that had failed. It has been in use since then without issues until two weeks ago.
When the new issue showed I was going at about 10km/h and it suddenly slowed to a halt. I started it again after that with choke and I drove it 400 meters and parked. Next time it was really hard to start, and since it was low on gas I thought that was the problem. It didn't get any better with a full tank, so I assumed it was the cold weather, and adjusted the pilot slightly.
After that it I actually got it started again with full choke and some slight gas, I drove about 300 meters and then it slowed down to a halt again. After that, it hasn't started again.
The compression is 165psi. The spark has good intensity, the ATV has functioned before with the same spark "intensity"/light. I *assume* that it has gas as well, there is definitely gas on the spark plug when I remove it
I have checked the carburetor slightly, the float works, diaphragm looks ok, but I haven't disassembled it to really look for dust and such in all the small places.
My theory right now is that it might've been some dust in the gas tank that went into the system, it's just a theory
I'm thankful for all the help and pointers I can get, don't hesitate
/ Pär, Sweden
By AussieKingQuad
View File 2007-2010 Suzuki King Quad 450 AXI service manual
Submitter AussieKingQuad Submitted 11/23/2023 Category Suzuki ATV
By akira gatewood sr.
Just bought 07 450ER and took it out for a ride(20 min) came back in and saw oil on swing arm. Upon further inspection found it was coming from air box. Wondering if it could be to much oil ( draining and refilling both tomorrow) , or possibly something worse. Guy isn't answering any questions now smh.. thanks ahead of time
Similar Tagged Content
- 1 reply
- 2,286 views
- 2 replies
- 2,202 views
- 14 replies
- 10,610 views
- 2 replies
- 11,498 views
- 2 comments
- 12,946 views
Gallery Images
By DJLime,
By splinter,
By onetoughzuki,
By Firewalker,
By chopt,
By berryjo5,
By Guest,
By shane36,
By osbornk,
By CK1999_400ex,
By Suzuki450rMan,
By zukeracer,
By adammiles,
