hi i have a 2007 polaris predator 500. it currently has.
-trinity stage 4 exhaust
-170 main jet
-15 tooth front sprocked (for more topend)
-shaved front fenders.
i just do NOT get it. i clocked it and it redlines at only 78mph. i want to do over 80 but still have good acceleration and be within a budget. can anybody have any suggestions of what else i should do?
78mph isn't bad considering you don't have alot done to it, and most other sport quads don't go any faster than that without a good bit of money dumped into them. 80mph without just gearing it up will take a few bucks. A good bigbore kit may give you the extra grunt you need to properly pull the tall gearing you are already running, that will probably get you over 80mph.
That would probably do it too, depending on how much over-rev you get, you may even be able to get your low end back by dropping your front sprocket down to stock size and still be able to stay over 80 on the top end.
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
