2004 Kawasaki Prairie 700 Starting Problem
garmi
Hello,
I have issues with the starting of my Prairie. I live in a 4 season climate where it is really hard to get this to run and start when it is cold outside. (40 or below) During the summer months it runs great. From October to March it is a bear to start. I had this engine rebuilt a few years ago and the guy who did the engine work did a great job but did not know how to start my machine after finishing the work. He kept choking and using the throttle. Not sure if this has now screwed up the reason why I cannot get it start in the winter.
My manual says that when you start this atv you just choke it from a cold start. Wait until the unit obviously is starting to overload with gas with choke on. After that when it kills turn the choke off and restart the atv by just giving it gas and it should run after that.
Now again only during the cold months after being choked and kills. I try starting the quad with giving it some gas and will not start. Multiple times of restarting it it will eventually finally run again. Once it starts I have to keep my thumb on the throttle to keep it running or it will die and have to try starting it again numerous times. This has to be hard on my starter. What do I need to do to fix this like it was when I first bought this?
I would try just turning the choke off before it loads up and dies. Did this problem start right after you had the motor rebuilt? If so, I would suspect that something he did may have caused this problem. If you can still get ahold of this guy, I would ask him if he changed anything like the carb settings and jetting. A pilot screw adjustment might help your problem. Tight valves can cause hard starting, you may want to check your valve lash too. Make sure your air filter is clean and a new spark plug wouldn't hurt any either. How old is your fuel?
i have an 04 700 and it requires me to choke it almost every time i start it the 1st time .. i always slowly turn the choke off as it starts to load up ... it is the nature of the 04 an 05 to be choked when starting cold ... it can be 80 + out and it will have to be choked the first start of the day . i changed the air filter and put a uni in it and it has been easyer to start ..you should run a high octain fuel in it also .. as that will make it easyer to start ... and it will run better and cooler ...
hi garmi minesota
from pontiacjim
what is happening, is the gas is not atomizing as fast when it is so cold . so when you think about that gas laying in the cyl. as a puddle , and its cold , it is going to take a hotter spark to get it to burn , that being said, check your spark plugs, wires , coils, battery, any thing to do with ignition, and when it is so cold the battery is less eficent , then the starter draws most of the juce from the ignition, and you end up with a no start. look for the little things , like poor grounding, not only loose conections, but under size wire from the battery to the frame, or wires that are badly oxidized. when it is so cold like that sometimes you can tell about this wiring stuff by jump starting , if it starts easy when you jump start , it probably is in the wiring . spark plugs if in doubt take them out , see if they are wet, if they are , the spark is probably going to ground before it gets to the tip where can ignite the fuel, new plugs.
hope this helps
Edited by pontiacjim
headers
hi, ck1999-400ex
from pontiacjim
most of these have to be choked when they are cold , it is just the nature of the beast.
when they are cold the fuel just does not atomize properly,so when you pull the choke you reduce the air intake making for a richer mixture , so the spark plug can ignite it better,if the spark plug is in poor condition this will add to the problem.
hope this helps pontiacjim
  • Similar Topics
    • By Params_sweden
      Hi!
      I got my KLF300 running again with your help a couple of months ago, at that time it was the ignition coil that had failed. It has been in use since then without issues until two weeks ago.
      When the new issue showed I was going at about 10km/h and it suddenly slowed to a halt. I started it again after that with choke and I drove it 400 meters and parked. Next time it was really hard to start, and since it was low on gas I thought that was the problem. It didn't get any better with a full tank, so I assumed it was the cold weather, and adjusted the pilot slightly.
      After that it I actually got it started again with full choke and some slight gas, I drove about 300 meters and then it slowed down to a halt again. After that, it hasn't started again.
      The compression is 165psi. The spark has good intensity, the ATV has functioned before with the same spark "intensity"/light. I *assume* that it has gas as well, there is definitely gas on the spark plug when I remove it
      I have checked the carburetor slightly, the float works, diaphragm looks ok, but I haven't disassembled it to really look for dust and such in all the small places.
      My theory right now is that it might've been some dust in the gas tank that went into the system, it's just a theory
      I'm thankful for all the help and pointers I can get, don't hesitate
      / Pär, Sweden
    • By joshua91673
      hi every one .anyone out there my issue is my kick start wont stay out  i have to have some one pull it out.  it pull out easy just wont stay out to kick it over .kicks over and starts no problem
      first post
      josh ohio
      I know I know, There are seemingly 10000000 posts about the fuel issues on the late 90's Suzuki LTF 250 Quad runners. But I just got my 1998 and I only got it for $200. It idles but nothing on throttle. I cleaned the carb, and ultimately I had to order a carb, fuel pump and petcock as cleaning everything didnt help. Any suggestions?
    • Get More For Your Device
    • By BCNemo
      I have a 2001 Yamaha Kodiak 400 (YFM400FWAN©) On a recent hunting trip a problem popped up and I hope someone else has experienced this, so that I can learn from them instead of going on my own hunt for an answer.
      The Problem:
      On cold days (sub 25 degree) I choke the Kodiak and it starts instantly. It revs up and runs on "high idle" without any problem. However when I return the choke lever to its "normal" position the ATV continues to run and a very high idle. I cant put it into gear until the idle comes down, which it doesn't. In order to use the bike I have to shut it off and when I restart it I must place it into gear before the engine gets a chance to rev up. It then returns to a normal idle and the machine behaves normally. This only happens on real cold days but it is a problem I want to fix. Can anyone offer some help?
  • Gallery Images
