We have 2 stroke & 4 stroke now a few co. KTM for one is doing a electric bike maybe. Why not a small diesel & and some bio-fuel. If a vw can get 40 somthing mpg. just think what we could get with a quad. Can we get that with a turbo please. Utility & UTV would be cool. Then in the real world I don't think people would go for it & the price would sky rocket.
A quad with a turbo would be cool, although i think electric is the future, once the batteries get better with more capacity gas will be a thing of the past :yes: Plus theirs no engine maintenance with an electric vehicle
Tagels just like my rc cars their is just more of a cool factor of hearing the 2 stroke over my electric even if the up keep is more on the gas & the brushless is just as fast if not faster. It would be weird riding a elect. But we do have the ability to adjust.
Electric engines !! sounds good but in my future!!
Wonder if my local law enforcement would pull me over in my neighborhood if I were riding an electric atv. There would be no noise to make the neighbors made riding in stealth mode.
And different controllers, different power curves different continuous and burst current limits. But then best thing is not having to deal with jetting and oil and gas and every other thing thats annoying about gas engines!
    • By tflack500tbx
      Background,
      Any Ideas?
    • By jordan_ATV
    • By Asand211
    • By Atomusthenes
