I took the fall skating & now with the same hip I tried to take out a tree & my quad was less than a foot from going down into the river. I went face first into the mud not to tasty. I've had a knot on my hip for 2 weeks now. The only thing my wife said is I wish I had been there with the camara and then lol. I don't know what happen to honey are u ok!
She`s having too much fun with this !!!!:laugh:Hope you get better !!! :laugh:
Honey are you OK goes out the door real quick. I just ended up trail rashing my back pretty bad and my wife showed absolutely no mercy cleaning it out for me:aargh:.
Hope you are feeling better soon.
Wyld1 women just don't understand. I walked in from a ride yesterday and went to tell my wife something and before I could finish saying I want to tell (she said what did you do now)! It's just no fun with all 4 wheels on the ground & going slow.
Edited by hangingon
I had got stuck near the top of a hill climb. the quad dug into the mud off camber. So I got off and tried walking it up in 4wd & diff lock lever pulled all the way in no luck. It was in the mud when it came lose it was going backwards and me with it. The brakes wouldn't hold it! it was just to steep and slick so I slammed into the tree at the bottom of the hill before landing in the muddy water face first. my quad made it's on path on the way down between 2 trees without much room in between after I hit the tree the quad was on it's own. You can all laugh now!
Edited by hangingon
Epic !!:laugh:At least your allright !!:yes:
    • By Frank Angerano
    • By SouthARriverRat
      Looking froward gaining more knowledge and seeing projects being built. Currently resurrecting some kind of Suzuki 230 quad. I believe. lol. Been sitting at the edge of the woods for 15+ years. Riding a all original 84 Honda atc 110
    • By Heymax
      I bought a 2003 Bombardier Quest XT 650
    • By That229Yamaha
      Hey guys, I’m new to the forum. What I got is a 2001 Yamaha Bear Tracker 250, got it as a project on trade and the problem I’m dealing with is a “no spark” problem and been trying to hunt down the cause for two weeks. I’ve replaced the stator, pick up coil, CDI, wiring harness, ignition, coil pack, spark plug, solenoid, battery, etc. and I’m still not getting any luck. Even tried bypassing the kill switch. I also noticed two things on this quad, another CDI under the back plastic by the voltage regulator, and a blue and green wire coming from the motor behind  the foot shift, tried to hook it up but it broke off and I’m thinking the broken wire would cause it to have no spark, if not then I need someone’s help on this and wanna see if I can get spark again. If anyone knows why I have this problem, the help would be greatly appreciated.
