  • 3 months later...
the belts cause friction on the clutches in the cvt system and then they need vents to help keep the clutch cooler ... it also allows ait to come in and actually helps cool the lower end ov the motor/block ... some atv's even have recessed areas in the lower parts of the motors that help kool the motor when the air flows through the vent system for the clutch ..
    • By sandman001
    • By marlon smith
    • By fixitforfree
