My Quad, starts fine, takes off fine, but when I get 3/4 to full throttle it spits and sputters. The carb has been rebuilt, stage 1 carb kit with filter, and RCM steel exhaust. I have a manual for this model, and I'm fixing to go down the long list of ELEC. tests. ANY SUGGESTIONS???????
I'm not sure on the Yamahas but my Kawasaki has a cvt belt and it can go into limp mode. I have not had this to happen but I have read up on it and the Kawasaki will run as if the reverse rev. limiter is on. But they can be reset. It may be worth checking into. I would also go back and recheck he carb.
    • By docdoug72
    • By wanrep
    • By wanrep
      YFZ05YYXH
      YF05RH
    • By Thekevinjb
      thanks
