By BruinBeater
Hey all, BruinBeater here. Just joined up from the Pittsburgh, PA area.
Got a Polaris Sportsman 1000 and a 570 in the garage that don't get ridden quite enough but looking forward to a family trip this fall.
I'm the unofficial mechanic of the extended family. In the past month or so I've replaced a transmission in a Chevy Silverado, rust repair on a Chevy Malibu, electrical repair on a Subaru Crosstrek, overheating issue solved on a Can Am Commander, and right now I have a pair of Grizzly and a Bruin 350 in the garage. Both have a no start condition and have been sitting for 2+ years.
By jannonballs
2001 Yamaha Kodiak. Rebuilt and cleaned carb after sitting for 10 years. Got her runnin but now this clunking noise is happening and sometimes the engine stalls hard like the tranny or clutch abruptly stops the engine. This was not happening 10 years ago. Also the clunk will happen and the rpm's spike. See video. Any ideas before I tear into it?
IMG_4791.mov -
By Mudseeker149
Just bought the atv, sounds like there’s sand in a bearing near the clutch! Any ideas?
By erkme73
Just purchased the subject 150. It makes a crunchy chunky sound when reversing. There was a lot of slack on the chain so I assume that was it, but when I took the chain off I noticed that the transmission output shaft has a lot of slop in it. I have to assume that's not normal. Can anyone confirm?
By TimothyLindblom
Hey all, I just picked up this Massimo UTV for $500. Got it home and replaced the starter solenoid which successfully got power to the starter. Starter spun but engine didn't turn over although the engine is not locked up. I thought it was a bad starter. Got a new starter put on today and it does the same thing. Pulled the clutch cover and saw the engine is trying to turn over but something is slipping and not letting it turn over. I figured it must be the gear on the engine that the starter turns. Where can I get that and can it be replaced without pulling the motor? And am I correct that that's the issue?
Thanks!
Short video attached below
