just sold our polaris xplorer to friends, they called last night to say they can't get it to start. they installed a new battery and changed spark plugs. i'm wondering since it sat for almost 2 years what could be wrong with it. it does also need a new gasline replaced, would this prevent it from starting possibly?
Only if the gasline is blocked. Go back to basics: fuel/air mixture (which carb may need cleaned/rebuilt, would be a good idea anyway if it sat for 2 years especially if it sat with old gas for 2 years), good spark, and compression and it should start if these all check out ok. Good luck!:wink:
  • 5 weeks later...
Could be your starter, it clicks like that when your starter is bad.... Happened to me and my dad.... But anyway I would try tapping the starter with the back of a screwdriver and hold down the starter button at the same time and see if it turns over. If it turns over you need a new starter.
    • By flyinbrian365
      What's Covered:
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
