Tech question for the gifted on repairs on a 97 xplorer 500 4x4
By Gwbarm
IMG_4910.mov There is some slack in there but most is taken up by the gear cover,if anyone with history with these machines has had the same problem, let me know your findings. Where i am now im looking for finding replacement honda gears on Ebay and try those. I suspect the original was replaced with aftermarket gears years ago and they just worse quality as the years go by.
By lester
I picked up a 2000 Big Bear 400 4X4 that was sitting around that I know nothing about. It will not start. I do have a red light when in reverse. When I take it out of reverse, I do not get a green neutral light, and when I push the start button the red oil light comes on but there are no noises, nothing else happens. How do I test the neutral switch and/or bypass it to see if I can get it to at least crank? And does anyone have other suggestions for me to try?
By Chucksta
Any ideas?
By vickijjones
Just purchased this 4 wheeler in June, now I need to replace 1 wheel bearing, 2 boots (on rear), figure just do both sides bearing & boots. Was told it had 2" lift kit on it.Read some where might need to get different boots since lift. Want to do upper & lower. Any suggestions on how to tell if it's lifted & boots I need?
By alexwv1863
I'm looking for a repair manual that's specifically for a 2016 Arctic Cat 500. I have looked in the downloads section and there's one but it's for 500,700 & 1000 models. When looking through it, things I'm trying to find to fix on my 500 is not specific for just that model, and it's geared more towards the 700 model. So, needless to say, it really isn't helping me. I really hope someone out there has one. Thanks.
