2005 Suzuki z250 quadrunner carb problems
By Chucksta
Any ideas?
By prdicon
Polaris it a bit cheaper.
Let's say 3-5 years from now.
By HondaRubi2022
Hello,
I have a 2022 Honda Rubicon and I have an issue where it won’t start, when I turn the key for power nothing lights up and it won’t start but the lights will turn on with the light switch, I’ve checked all fuses and they’re good, I don’t have a wiring schematic I’m not sure where to start, I checked the ignition fuse when I turn the key on and there’s no voltage there, I used a jumper wire from the batter to the top of the ignition fuse and then it works fine and starts fine but as soon as I turn the quad/key off it won’t start again until I jump the ignition fuse with battery power, just wondering if anyone could give me some tips where to go with this or if anyone has had the same issue, thank you.
By Johnfj44
I met a guy today in Columbia TN at a dealer service area. He asked me if there was someone near Jamestown TN where he could get his nolder 4-wheeler serviced. I couldn't help but I gave him the Quadcrazy site and invited him to check it out. I decided to see if I could help him out before he even got to a forum to ask the question. Good Luck.
By QuadDad22
Picked up a 86’ LT 185 for $10 in trade value(my items only cost me $10)
recoil only , I pull the recoil and it won’t move , so I took it off , I can spin the crank there one full turn left then it locks up , and one full turn back to the right and it locks up
pulled the plug , the piston is moving up n down , both valves are moving(pulled the caps)
pulled the clutch off , oil pump gear , and it still locks up after one turn
any ideas or where to go from here would be greatly appreciated
im a 2 stroke guy so this all is new to me
thank you in advance y’all
