2011 Can-Am Outlander MAX 800 LTD EFI 4x4 (Illinois)
By bighoss
i got my son new outlaw 50 a few weeks ago and we went rideing yesterday and while we were riding it died and it took me like 10 min to get started back and it died agen when we got close to truck so i pulled it back took the plug out it looked like it was drop in a bucket of gas took the air filter out and the ait box was full of gas also got home it started rite up today i started it it starter up but was blowing what look like water out of the exholst let it idel for a lil bit did not die but as soon as hit the gas and let off it will die what does that sound like i thnk i going to take it back to dealer and tell them to fix it as it is under warrenty but would like to know what it could be first
By quadcrazy
QUADCRAZY NEEDS YOU!
By semicolon
By kantrud97
Thank you in advance
By Sofaspud
