open air box
By Adamb2025
By middlebrookgt
By Kurt Reiser
My quad will not run with the airbox hooked up Will not go past quarter throttle as soon as you unhook the tube at the back of the carburetor it runs great does anybody have any ideas what it could be I have a bad fuel pump one on the way can that cause the quad to run like that
By davefrombc
Anyone carrying a power box when camping with their ATV? I built a custom one. I used a marine battery box that has 2 50A Anderson Grey connector outputs ( changed one of the greys to a red), an accessory socket and2 USB outlets,and a battery voltmeter .. I added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the output posts.. To charge the 100Ah LiFePO4 battery I put in the box, I added a DC to DC charge adapter that I made input connectors for to allow charging the battery from a vehicle's accessory socket or a solar panel.
It was a fun project.. Besides having a 1,000w power box for 120V ac , USB and 12v accessories using the 10 A socket. I have 50 A Anderson connectors and the 120 A connector to run things like a 12v electric outboard for fishing trips . The LiFePO4 battery only allows a max output of 100A so it can't be used for something like jump starting, but it is half the weight and delivers twice the capacity of a lead acid battery running accessories.. Commercial pow2er boxes don't deliver high draw 12v output to run things like the electric outboards. That's one reason I custom built mine. One box that serves for both camping and fishing.
By dkgg5755
Im not getting 12v to ignition switch with key off or on I've jumped brown wire from starter relay to positive and neutral light comes on and push button start works. Can't figure out where to go from here any help appreciated l.
