i saved it off the back of a scrappers truck, $150 bucks! i did a full rebuild on it. new waco piston and rings, all new gaskets, brakes and cabals, and new mosse raceing barrings and spindels
    • By joshualutz
    • By USRaider
      Hello all!
    • By marlon smith
    • By tin
    • By dkgg5755
