i have 2007 kq 700 that will not start without battery charging . changed plug, new starter,new battery . it will turn over and act like it wants to start back fires but will only kills battery put charger to it starts right up . it has been smoking some if that helps . please help:aargh::aargh::aargh:
Will it run after it starts without the charger? put a meter across the terminals without the charger on and have the bike running. A reading of 13.2 or higher is preferred. If not check the alternator output. Refer to your shop manual for specific procedure.
Not sure if regulator is internal or external but it could be bad or alternator is bad
  • 3 months later...
    • By docdoug72
    • By Tinkeringreg
