2005 Grizzly 660 warms up then cuts out
I bought a Grizzly 660 not very long ago, it has engine mods as well as a new pipe to breath through. I've noticed I can't ride for much longer than 30 min before the machine starts cutting out, if I let it sit and the motor gets cold it will run just fine again until it re-warms up. I replaced the water pump workings and seals as well as flushed the radiator and given fresh coolant, the spark plug is a perfect shade of brown so I know that the motor is running as it should. I didn't have this issue before putting the pipe on but can't see how the pipe would cause this. Any thoughts or help on this issue is greatly appreciated
It bucks a lil while riding after warmed up and will stall out if i get off the gas but will idle fine, it's got (according to the local shop) a 180 main jet. The jet is a guess since its a lil hard to read, but looked spot on compared to a new one.
I have been thinkin bout the radiator idea myself as well Ox, jus tryin to find a slightly cheaper alternative
    • By McG75
      Sorry I suck at these forums so if you see this submitted under update status, my bad. Anyhow this is a new shock for a 96 Yamaha Kodiak 400 4x4 it fits my 96 Yamaha Timberwolf 250 4x4 perfectly. Little narrower are the bottom than the original but everything else is perfect. I extended it to almost a half in from full extension because I’m pushing 350 pounds.  It rides and hold me well. So if any of y'allRace driven shock. have been looking for one and didn’t want to do the research here it is.
    • By DrtyGrlKristin
    • By Drillbit
