Ok, I sent hubby to the local cycle shop for some 2 stroke oil and it was closed. He stopped at Home Depot and picked up 2 small bottles of 2 stroke oil with stabilizer in it, but it is synthetic lube. I still have some regular oil in the injector, but not synthetic. Can I add this to my oil injection with the regular oil in it, or should I disconnect the injection unit and just run premix? I used to run Castor 927 premix without the injection, but is easier for my son to just add gas and go....anyone got a comment or suggestion?:huh:
and the Castor 927 states specifically "not for injection". Makes sense to me Wylde1 to let it go down and add, but can u even use it with injection? What do you use? But then as Oxy said, do I have to continue with synthetic? Maybe I should just go get some more regular 2 stroke oil and use the other stuff for the dirtbike and the weedwacker...:confused:
I am actually using Kawasaki Jet Ski oil now, because it was on a closeout. I got a gallon for the same price as a regular quart. I have not had any problems with it. I have used Yamalube and a synthetic blend previously. I haven't had any problems, although the Yamalube gave new meaning to the phrase "two-stroke smoke." lol
I did some more digging and found this.
Drummer,
If the experts say mixing conventional oil and synthetic is not good....why then do most if not all of the major oil producers sell conventional/synthetic blend oils?
Motor Oil, Transmission Fluids & Synthetic Oil | Quaker State
Myth 4: Switching between synthetic and conventional You can't switch from synthetic oil to conventional oil or mix the two.
Fact You may interchange synthetic and conventional oil as long as the synthetic motor oil product and conventional motor oil product meet the viscosity and performance requirements outlined in the vehicle’s owner’s manual. Synthetic blends, in fact, are a mixture of conventional and synthetic-base oils.
Mixing Synthetic and Conventional Motor Oils
Question: Mixing Synthetic and Conventional Motor Oils Can you ever blend synthetic oils and conventional oils? If so, what is the ratio? -- Julie Patten, Des Moines, IA Answer: Yes, synthetic oils can be blended with conventional oils. Several companies, including ExxonMobil, market synthetic blends which are a combination of synthetic and conventional oils. In the case of ExxonMobil, the ratio of synthetic to conventional oil in these products is considered proprietary information.
Here are some "blend" oils
Bardahl Synthetic Blend 2-Stroke Engine Oil Salt Lake City, UT, Honda, Kawasaki, Polaris, Yamaha, ATV, Motorcycle, Scooter, Snowmobile, Dealer, Used, Parts
PJ1 Goldfire Pro 2-Stroke Racing Oil
Yamalube 2-S http://www.yamahagolfcar.com/accessories/acproduct/5/sm/7/48/yamalube_2-s.aspx
OPTIMAX/DFI 2-CYCLE OUTBOARD OIL http://northamerica.mercurymarine.com/otherproducts/maintenance/dfi.php
Dang Wylde1,,, that is some great reading!! It simplified it and I'm gonna mix it tomorrow...hell, if it blows up, I still have that spare engine!!! Thanks a bunch!!:wink:
No I don't want you to blow it up.:no: From what we read and the fact that I have been mixing it up and haven't had anything catastrophic happen:biggrin: you should be OK. Just to be safe I would maybe take a short run and be easy on it to make sure before getting crazy.:yes:
LOL! That's the spirit! WFO FTW!!!
I ran synthetic and dinosaur oil mixed in my sleds all the time. Didn't hurt the injector pump, foul plugs, or effect mileage. Alot of that is BS based on performance statistics and sales tactics. ANY oil is better than none @ all. I'd say run the oil tank as low as possible then fill it with the synthetic. I know quads might be a tad different because the intention is to be run in warm weather but I've never had a problem in the sleds. Try it!
    • By Atomusthenes
    • By worldmotocentro
      FOR SALE : YAMAHA 300 HP 4 STROKE
      Purchase your choice of quality outboard engines at affordable prices
      New & Used Outboard Motors (2-Stroke and 4-Stroke)
      Brands: Yamaha, Honda, Evinrude E-TEC, Mercury, Suzuki, Tohatsu Jet Skis, Sailboats, Powerboats, Watercraft, and Snowmobiles
      For Inquiries, Contact Us:
      Whatsapp Text: +1 (217) 460-7668
      Email: [email protected]
      Brand: Yamaha Motor, Yamaha Motor
      Weight: 229 kg (505 lbs)
      Manufacturer Item Number: Lf300xca
      Inbox if you're interested
      Contact for Purchase.
      Whatsapp Chat Number: +1 (217) 460-7668
      Unleash the ultimate performance on the water with Yamaha’s 300 HP 4-Stroke Outboard – built for speed, strength, and reliability.
      ✅ Unmatched Power: Smooth, responsive acceleration with 300 horsepower at your command.
      ✅ Fuel Efficiency: Advanced 4-stroke technology gives you more time on the water, less at the pump.
      ✅ Quiet & Smooth Ride: Yamaha’s cutting-edge engineering delivers powerful performance without the noise.
      ✅ Built to Last: Rugged design and legendary Yamaha reliability keep you running season after season.
      ✅ Smart Technology: Integrated digital controls and monitoring for precision handling.
      Whether you’re chasing fish offshore or enjoying high-speed runs, the Yamaha 300 HP 4-Stroke is engineered to take you further, faster, and stronger.
      ⚓ Yamaha – Reliability Starts Here.
      📞 Contact us today for pricing, availability, and special promotions!
      +12138024396
    • By Matdum
      Is it common to replace them ? I think one of mine doesnt mist well and cause too much fuel goes to exhaust. Motor is full rebuilt and stink , like combustion isnt going very well
      anyone?
    • By DemonQuad666
      I'm sure this has been tossed around on here numerous times but with the unveiling of the new KTM fuel injected 2 stroke. Could this be the first step in a come back for my beloved double ding ding machines. Ok lets hear it. Why do you like one or the other??? Myself, I always felt it was the throttle control and Powerband response with the 2 strokes. I know this sounds weird but on a 4 stroke, no matter size or model. I always felt like i was along for the ride instead of in control. I've spent hours on my buds 400EX, even took a new 450r for a spin. before they discontinued them. Blasters, Banshees, and a number of 125's, 250's and even one late 80's Honda XR250R... Results all the same. For me its a comfort and control that im used to with the 2 strokes.... and i love the smell of bean oil... So lets hear it. Im sick of arguing with same two people at work on this issue.
    • By Eisaks777
