  • Join Today, It's Simple and FREE!
bradken19
1997 Suzuki King Quad - Starting Problems
the king quad had sit for about 1 1/2 years. So I rebuilt the carb and now it will not start. Any help will be greatly appreciated.
Share this post
Link to post
it will not even start when spraying starter fluid in the air box, but it will start if I spray the fluid in the rubber boot after the carb. After it starts, it will run perfect until you shut it off for a while and then it will not start again.
Share this post
Link to post
there's something not right in the kit rebuild, something is still plugged somewhere or the choke is plugged. you really need those garbage bag twist ties to clear all the passages. i know, i had mine apart and put back together 5 or 6 times before i did the twist ties, and after that it worked perfect ... just a suggestion ... can you tell if the bowl is getting gas?
Share this post
Link to post
COMPRESSED AIR is your best friend when it comes to carb cleaning. just make certain all the rubber diaphragms and o-rings are out of the carb body before you use it. small parts can almost go into orbit with 100+ psi of air! i also use a spray can of carb or brake cleaner to verify that all of the tiny passages are open. MAKE CERTAIN you wear safety glasses doing that! an eye full of chemicals will feel like your eyeball has 2 foot flames coming out of it. and depending on what it is, possibly even permanent eye damage. DON'T ask me how i know that!
Share this post
Link to post
On 3/31/2019 at 2:28 PM, Ronald van Belkum said:
I thought the battery was bad. got a new one and it still acts like a dead battery. Turns over 1-2 times then click.  I have a 1997 king quad. 350.
Did you check all your electrical contacts from battery terminals to starter?
I did that with mine as well as taking the starter apart and cleaning it well.
Works like a champ now.
Share this post
Link to post
Yep.
Or the notoriously bad petcock.
Anyway, it appears there are multiple topics going on here.
Share this post
Link to post
  • Similar Topics
    • By Mike Johnson
      Does anyone know what the 3rd item is behind the battery on this ATV ? I know 1 is the,  solenoid1 is the CDI box, what is the 3rd.
    • By Daniel Gibson
      Working on a bayou 220 that has been ran extremely hard it's whole life. Literally had almost an inch thick dirt/oil covering the motor. Yeah that bad. Surprisingly it runs though. I cleaned the carb and tank multiple times. They're clean enough to eat off of. Readjusted valve lash and set timing. Was about 3 teeth off. It cranks good and runs good only problem is I have to cover the carb intake basically choking the hell out of it for it to start. The com choke works fine. It does this each time I start it regardless of temperature both ambient or motor. Wth? Compression is at 115psi I get 130s if I put a little oil in the piston chamber. Please help. Thanks
    • By JC4x4
      My Honda Fourtrax won't start. The starter is kicking the engine over, but it won't start. It sat for about a year while I was living away, so I thought it might have been bad gas. I completely drained the fuel, flushed the fuel lines and filled it with fresh gas. However, still nothing. It started and ran fine the last time I used it. Any suggestions on how to diagnose this? It could be fuel or electrical at this point. Is there an easy way to rule one or the other out? Thanks
    • By pcumby
      Hi guys I'm in the market for a new ATV.  I narrowed my choices down to King quad 750 Grizzly 700 and Rubicon 520,  I own a 2006 500 Rubicon right now and I like the reliability and power for plowing.  However it is not a capable ATV.  When quading with other guys it falls short with ride quality and ground clearance.   I also have a 500 King Quad 2015 which I like and will keep it for my wife.  It is very strong and reliable also.  However my plan is to sell my Honda Rubicon and replace it with a 2020 of one of the these mentioned above.  Can anyone give me their take on one or all of these machines and why you picked what you picked?
    • By Quadrunner44
      I have an older 1980s Suzuki quadrunner red lt 4wd (250)
      so just finished putting it all back together and was running fine just needed to adjust the rebuilt carb
      bf decides to hook up an air chuck to the gas tank because it got a shot of air in the gas line well 120psi didn’t agree with any of the parts including the new carb
      end result : new battery new carb now it just clicks (one single click) won’t turn over
      hard to pull start gets hung up (unless I remove the spark plug ) gas flooded out the first time but now does nothing purchases a new starter waiting the arrival
      could there be damage to the crank shaft or pistons etc? Or install the new starter and try to fire it up ? What caused the starter to die after he flooded everything with gas was working fine.
      Thank you
  • Similar Tagged Content
    • By Dana Hudson
      Hey everyone, hoping to get some help here... my kids 03 KTF 50 Quad has always ran great... they were riding it a couple of hours a few days ago and it died a couple of times (not normal) but started right back up. A few days later my 5 year old wanted to take it for a spin so I started it (2 pulls) and he took off.. he made it a couple hundred yards and it died and we havnt been able to start it since. I have new gas, good spark and 120 psi compression.. it will not start with starter fluid in the intake or even in the cylinder.. the fuel bowl has fuel at the carb... what am I missing? It’s driving me crazy!!
    • By oxidized_black
      tag : zukifreak
    • By LTZ-Zach
      So i was riding the other day and my quad randomly shut off. It started back up and ran completely fine for a little while and then it started idling terribly.
      I cleaned the carb and changed all the jets and everything except the float due to the rebuild kit not coming with one and it actually runs worse then it did before.
      It will run and idle decent now but when I give it gas it dies.
      Does anybody know what could be wrong?
      I also changed the spark plug and air filter along with the oil and oil filter.
    • By johnwayne
      i have a 2000 suzuki king quad lt-f300f that i picked up as a project bike. it didnt run well when it was parked outside 5 years ago. it cranked after putting fresh gas - but would not run below half throttle, i took apart the carb, cleaned debris, and re-assembled. i suspect that the pilot needle is sheared off - it never protrudes into the throttle body through the pinhole. now to get the bike to ALMOST idle, the throttle idle adjustment knob is all the way up/in. the pilot needle is turned almost all the way in/up (if i understand correct, it should nominally be out 2 1/4 turns or so). and like i said, it will ALMOST idle. floods easily, rides rough.
      wanted to hear from those more experienced than me with suzukis - and im self-taught atv repair, so dont laugh too hard if my verbiage/part names is way off.
      facing the driver's side of the bike [US] there are three hoses on this side of the carb. without a service manual or way of knowing what was messed up before i got it, i think i have them right: front hose as a vacuum to the petcock, middle hose as vacuum to the fuel pump, rear hose as fuel line from the fuel pump. running the bike in prime position results in flooding even while riding. with all hoses disconnected from the carb, fuel slowly drips from the vacuum line connected to the petcock.
      so just my speculation is that the diaphragm in the petcock is split, and the pilot needle is broke off - causing my inability to not quite idle and the rough ride. this suzuki is hoses and cables everywhere compared to the honda ranchers and yamaha warriors i am used to. I would like to have a plan rather than: replace everything at once.
      is my speculation on the right track, or could something else be at play? say, if the compression was non-existent, would that cause non-idling? i am all ears, look forward to the input.
