i just bought a 97 350 warrior guy told me he had it in pieces like every thing even motor was tore arpart before i bought he had it all back together got it home put battery, new oild in it and started it up made a weird clacking sound sounded like timing chain was lose checked it, it was good and tight looked at started gears theye looked good coul;d use some advice cause not sure if i should pull heads off make sure pistions not on backwards had the once before and it broke the rocker arm
i just sold a 2001 warrior because it kept cutting out . i had it rebuilt and then it just started running funny . i had it to just about every shop around here but they couldnt figure it out. sold it last month for $500 just put brand new plastic on it a couple years ago. the guy took it to his friends and figured out there was a wire hooked up backwards. i ve kicked myself in the butt ever since .
ya got tired of trying to figure out what was wrong with it. so the opportunity came up so i got rid of it. sucks i sunk a lot of money into it but what the hell its making someone else happy so i guess thats a plus
yea been there had lot of people bring them to me for that reason but lol never ran in to my problem yea pulled off clutch cover wehn ta macth up balancer and crank shaft gears they was 8 teeth off i re aliagned them got it back together runs great all u hear is fmf pipe nice
    • By tds7
    • By middlebrookgt
    • By Rick Shropshire
