bought 2005 king quad 700. got burnt now need motor and transmission
Details Details more info needed !! most motor problems can be fixed without replacing the whole motor or tranny :yes:Tell us what happened !!
oil pump chain went through bottom end. oil pump was broke off and made whole bigger where the rod goes through case. and need new crank and piston. and i didn't get to ride it yet. i brought it home put it in garage. was going to take it to have it looked over to see if it need anything, and that is when chain went through bottom end. so took it over too have then look at it and now found all that wrong with it. and more.
Wow !! it gernaded on you !!:no:those motors are usually indestructable !!
    • By fixitforfree
      I have a 94 Trail Boss 250 2wd that will not go into forward. Reverse works great but forward just clicks but won’t engage. I’ve verified the shift lever is pushing far enough so I believe I have either an engagement “dog” or mating forward gear that are likely bad. I also see a fair amount of metal on the dipstick magnet. But if I ride the machine in reverse the gearbox seems quiet with no other issues by what I hear. That said I’m in process of pulling the gearbox to see what parts I need. The gearbox has 1341124 as the model number as shown in the photo below but I can’t find any gearbox on eBay or the Polaris parts site that matches that number. Is this 94 model a year that used some special gearbox? My tag on the box even looks different than all the tags on gearboxes I see for sale on eBay. I really want to buy new parts for the ones damaged in my gearbox to fix the one I have but just doing research at this point to see what gearbox I have to know which parts I need. Anyone with experience with this I welcome some advice or direction from what you have learned. Just FYI this machine is new to me but cranks, runs and idles perfect. It’s not beat up and will be a gem when I get this tranny fixed. Thanks.
    • By maikytech
      Has 60 psi and motor recent flooded...what the true compretion
    • By Norseman69
      Hi. I just bought an lt230 1993.  Ive started buying parts for a full rebuild.  But somehow beskepedal has been removed and pegs welded to where They are supposed to be screwed.    I was wondering if anyone have one and Could measure how far out the pegs are.  Like the peg the brake is put on and then peg outside of it.  And the one lower down.  So i can recreate them.
    • By Heymax
      I bought a 2003 Bombardier Quest XT 650
