2005 big bear 400 4x4. My neutral light has stopped coming on and the bike will not start. I know its in neutral because it will roll. Cannot get it to start with the hand brake or pull rope either. When I push the start button, all that happens is the oil temp light flashes. All the fuses checked out and the battery is hot. Looked for loose connections and I haven't found any. Any ideas? Thanks for your help.
...if the battery is hot there could be another issue in addition to the neutral switch going bad.
I would also check the cables/connectors to the starter. You may have a bad cable/connection or bad ground. This may have been part of the cause for the neutral switch to go bad...
My oil filters on the right side and I cannot find this switch to save my own life. Anyone know where the neutral switch is on a 2005 400 big bear?
not recommended for safety reasons, but, you can easily bypass the neutral safety switch by installing a starter button attached to the starter solonoid, ........ turn key on, push button, 4wheeler starts, btw it will crank in gear with the neutral safety switch bypassed
    • By Rockbottom
      What should i test next?
      thanks ahead
    • By Mister907
    • By Brent Wright
    • By HeWasRidinDirty
      The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
