By Chucksta
Any ideas?
By p5200
The studs in the sprocket hub are stripped out. The hub is probably walloed out also. Probably will have to have a new sprocket hub. I doubt I have the ability nor the tools needed for this job. Thanks for all suggestions/opinions!
20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4
By dvs1961
By That229Yamaha
Hey guys, I’m new to the forum. What I got is a 2001 Yamaha Bear Tracker 250, got it as a project on trade and the problem I’m dealing with is a “no spark” problem and been trying to hunt down the cause for two weeks. I’ve replaced the stator, pick up coil, CDI, wiring harness, ignition, coil pack, spark plug, solenoid, battery, etc. and I’m still not getting any luck. Even tried bypassing the kill switch. I also noticed two things on this quad, another CDI under the back plastic by the voltage regulator, and a blue and green wire coming from the motor behind the foot shift, tried to hook it up but it broke off and I’m thinking the broken wire would cause it to have no spark, if not then I need someone’s help on this and wanna see if I can get spark again. If anyone knows why I have this problem, the help would be greatly appreciated.
