I just purchased my atv and the 4 wheel drive is engaging and disengaging while riding the bike in HI 2WD. Any ideas??
Edited by ejroot
More descriptive
You may have got water in the 4X4 actuator or the plug from the harness. This is a common problem. It happened to me once and then never again. Let it dry out and take apart the plug located right next to the front diff on the actuator and make sure you apply dielectric grease to the connectors. See if it stops engaging and disengaging. If that does not work the next thing others would try is taking the actuator off and opening the cover to dry it out and silicone the case back together. There are so tricky springs in there so make sure to be careful when taking apart and do not loose any of the parts when they fly out. I would only take it apart as a last resort before replacement, I really think the first idea would work.
    • By mehim
    • By quadnut20
    • By Shorty51
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By HoldenBoy
      Hi all,
