90' suzuki 250 quad 4x4 will act like choke is on after 4 minutes of run time. Cleaned and inspected carb. Just acts like it doesn't have power after a couple of minutes running , It seems when the heat builds up throttle response just keeps getting woorse unit it won't keep running
espeacially at idle.
Any imput appreaciated.
Yamaha 225
We also just had a valve job done and adjusted the valves. I don't think comprssion is a problem.
It just seems like carb trouble. We completely had it a part and cleaned all jets and choke chamber
and seems to run okay except for the idle screw with cable is truned all the way up. I have the other ajustment screw turned out 2 turns. Mikuni 130 cc carb.
    • By Elk
      2002 Polaris Magnum 325
    • By jay41198
    • By kevinohio
    • By buriedpast
