Thanx for the information. Much appreciated. I was able to locate the diode and it has failed open. Does anybody know where to purchase a fan diode from? They want $640 for a complete harness. I diode is worth about $5.
Off the top of my head you are looking for a 10 or 15 amp blocking diode with axial leads. Check Online or Radio Shack.
Radio Shack does not sell a 10 amp diode but they do sell 5 amp ones and what you can do is they come in a 4 pack or something like that. Solder two in parallel and that will double the current it can handle. Make sure you have the polarity correct when replacing it.
Swampcat is right, the diode is inside the wire harness near where the fan connection mates into the harness.
Mike
Thanx guys for the info. The PN junction of the diode turned out to be okay. The Anode actually broke off and the cathode was barely hanging on. A little solder and some patience and we are back in business.
    • By tepin
    • By randyoct
      Will the top end of a 400 fit a 366 the price is so much cheaper
    • By spigmef
      I bought a 2008 arctic at 366 with 120hrs. When i red line it in neutral is smokes blue a lot. When I put it in high range it has problems getting over 35km/h. I bought it and had to clean the carb. It ran ok after i cleaned it. Not I have this problem.
    • By ath1981
      Got a 2011 425 EFI. It eat 2 belts, so I replaced the drive clutch assy, rollers, spacer and movable face. Put on a new belt and after 30 min of riding, it eat another belt. any clue what can be causing this?
