I recently got a Kazuma 250 I think. I installed new battery and key assembley its only turning on when its connected to the charger.when it is on it shakes back and forward . It rolls backwards . I try to give it gas but it shuts off . Do I need a new alternator so it will cut on with out being connected to the charger
Also I got some B-12 Carb cleaner and it seemed like it helped a little
****Pictures are on my page I couldn't load them from my phone
ALSO IT BEEN SITTING FOR I DON'T KNOW HOW LONG SO SHOULD I LET IT RUN AND LET THE CARB CLEANER GO THRU THE SYSTEM
i would try to get it running fairly smooth first and see if you have the same problem with the forward motions. you could check the drive belt in the meantime and see if its worn and/or narrowed with wear. it seems the chinese brands electrical harness and components are not as reliable as the japanese. i would just try and get it running smooth and go from there, and yes, run the carb cleaner thru the carb and hopefully you won't need a rebuild kit or alot of heavy duty cleaning by dis-assembly ...
    • By tds7
    • By joezee13
    • By shorty
      FYI: I used a volt meter to test the stator/rotor output. Pulled the plug on the rectifier/regulator to access the 3 wires coming from the stator. The other 2 wires are 12v pos and negative so easy to identify the 3 stator wires, which are yellow on my Kowhockey. You should see around 30v AC not DC coming from the engine stator. Test all three wires to EACH OTHER not ground. Remember the stator puts out AC like an alternator. The rectifier converts the AC into DC to charge the battery. On my case the rectifier/regulator was bad, obvious because the 3 stator wires showed 30v AC
