Hey guys could use some help here. Have polaris 400 95' dang thing no matter what i doe for adjusting the carb still does same thing. Cleaned it thoroughly. Seems to start fine when choke is open but as soon as i take it off it revs up for a second then just dies. Plus doesnt seem to idle properly. Have adjusted the idle screw and air fuel screw to no end still have same problem. Need help anyone? Anyone?
You are going to have to take the carb apart and clean it wit compressed air to make sure every fine particle of dirt is out. I worked on one all afternoon tearing it apart 4 times before I got it to work right. As for it accelerating when you close the choke means it is sucking air from somewhere and then stalling out. Make sure you are not missing any parts when you put it back together. Try to get a manual if you can.
  • 9 months later...
    • By Tinkeringreg
    • By Travis_Smith
    • By Dumass
