2000 Suzuki Lt80 - Won't Start ~ Help
pmcloud
i have a 2000 suzuki lt 80. whenever i try to start it it cranks like once and then stops , i do this like five times in a row then the circuit breaker pops, then i reset it and try it agin but it still doesnt start. the battery is fully charged. any ideas?
Edited by pmcloud
    • By Spritee1
      not sure where to look next
    • By NZrider
    • By jatho
    • By mkibbe
    • By jatho
