I need to pay attention to detail I posted I got my radiator put in my quad & now it is running rich & will not idle. I guess it's been too long since I rode it my daughter rode it last. The Brain Fart I was running it with the choke on. you all who read this can laugh now. I'm sure I left it on & my daughter just rode and didn't know about the choke.:aargh: Any way it's running good I went out and rode on the trails and spent alot of time trimming back brush and pulled a tree out of the way that was across the trail Thank God for 4wd & low gear.
Edited by hangingon
Ox I loved how easy it was to fix. I'm glad I didn't start tearing it apart before I caught on that the choke was on. My friends mothers lawnmower would not start he used a battery charger to jump start it , pulled the starter off to check it & I don't know what all he did before his mom rememberd she left the blades engaged so the safty was keeping it from starting but he tore into before looking at it over for the simple things.
    • By Jason39
      I’m having a issue with my choke when its on it runs fine when I cut the choke off the atv cuts off went to take the carburetor off and saw the choke plunger broke at the nut to screw it in could this be my issue? Do I just need to buy a plunger kit and put it on? I took the carburetor off and cleaned both jets anyway just to make sure and it’s still having issues staying on
    • By PupATV
      Hey guys! I am new here to the forum and need some help getting my Polaris 325 Magnum 2001 Running.....So I got it for free and it has never run quite right...I put a aftermarket carb on it last year and it was running fine but it only went like 20 maybe 25mph max......But then the needle and seat sealed leaked within a yeah and it flooded it REALLY bad so I changed the oil because it was full of gas. So then I put a genuine Polaris carb on it and I have it set to all the factory specs, but it was still not running right....So I replaced the ignition coil and the spark plug and that solved one of the problems I had (It would bog down and stop running when i would go up a hill) But it still didn't have that much "Punch" to it like my Kawasaki Prairie 300 ans Suzuki Kingkuad 300.....So I replaced the CDI but it's still not running right! It's acting like it rich kinda....So it runs mostly okayish when I have the airfilter on but the top of the airbox off but as soon as I put the airbox lid on it like REALLY bogs down and wants to stall really bad. I have the carb at the factory specs and it has a pretty new fuel pump so I have no ideas whats going wrong! It still nly has a top speed of only about 30-35mph and it sounds like it's choking the whole time! Thank you for sticking to the end, and I hope you guys can help me!
      -PupATV
    • By bhristianzx12
      I have acquired a free 92 Polaris 350L 4X4. Ive replaced carburetor from ebay, replaced spark plug, im trying to pull start but sounds like it doesnt want to fire. Spark is a bright orange spark (checked with spark plug tester), replaced plug, pre mixed gas from an external gravity feed tank. Compression test good. Anyone got any recommendations for me?
    • By jhamrick75
    • By Starsat
      The choke lever doesn't stay in position on my 2001 Yamaha Kodiak.  The model is YFM 400.  I have to hold the lever to the choke position manually for some reason.  Any Ideas as to why?
