425i clutch/belt cover very hot on leg
By
sidmabb, in Arctic Cat ATV Forum
Similar Tagged Content
By WeekendATVdotcom
We had a chance to review Dowcos Guardian Trailerable ATV Covers, an ATV cover designed to be hauled in your truck or trailer. Its a great solution if you are looking for a heavy duty cover. REVIEW: Dowco Guardian Trailerable ATV Covers - WeekendATV.com
By gignac02
Last year i have changed the timing chain on my 1997 TRX350. I did use silicone between head and cover. now it is leaking. I am looking for a better product than silicone to put between cover and head. What should i use?
By jessisue1982
Ok my 2009 Kawasaki brute force 750 4x4i is back firing & cutting out when excellerated and the engine is getting hot enough that it burns my leg through jeans and it feels like the exhaust is melting the fender and I can sometimes smell burning plastic.
I checked the fan and it is fine, also pulled the fuel pump out and tested and cleaned it and it stopped back firing and cutting out but still runs hot but not showing the temp sensor indicator light on the dfi at all... I checked the plugs and cleaned gapped ect they are fine... radiator is clean and not stopped up, oil level good, injectors working property and clean..... I just don't know what else to do to it.... HELP!
By yamaha225
90' suzuki 250 quad 4x4 will act like choke is on after 4 minutes of run time. Cleaned and inspected carb. Just acts like it doesn't have power after a couple of minutes running , It seems when the heat builds up throttle response just keeps getting woorse unit it won't keep running
espeacially at idle.
Any imput appreaciated.
Yamaha 225
By polaris400
I own a 1998 Honda 300ex The last two times I rode, probably for about an hour,I shut it off for ten or fifteen minutes and when I went to ride again it backfires and then stalls out. Also the motor seems incredibly hot.Then if I let it sit for a long time it starts and runs fine.Can anyone tell me what might be causing this and what will fix it? Thanks a lot!
Similar Topics
By YamahaGrizzly
We got HEAT in Grizzly Cave! Thanks to Brandon Pitcher Make sure to give this video a like and commment on youtube! It helps us grow! Road to 3k Subs lets goooo -
By Samwise
I don't have a manual and want to do an oil change. What is the recommended oil. Are these wet clutch? Can I use synthetic? Kinda at a loss for what to buy. Obviously oil changes aren't that expensive so not afraid to buy a good quality oil.
By Samwise
Just bought a 2012 yamaha big bear. Been without one for way to long. Lift kits? Obviously high lifter is a go to. Any recommendations?
By Samwise
Back in the saddle. Any of y'all have.any suggestions on stuff to keep an eye on that might be problematic with these.
By Chris Cowell
Hey fellas. So I have a 2012 yfz450r. I work on the road for a living and went to a job and let a friend of mine borrow my wheeler while I was gone. Well, we know how that all turns out. I come home and it’s not running. Swears up and down he just went out to start it one day and wouldn’t start. Well, I start fooling with it and figure out the fuel pump is bad. I replaced the pump a couple days ago and brand new battery. When I go to start it, the engine light blinks every time I hit the start button. So, I decided to try and pull start it. It’ll turn over strong and half-ass run until I pull in the clutch and dies. Then the fuel light came on. I can hear the pump turning on and doing it’s job. Now, when I turn on the key the fuel light stays on, and same deal with engine light blinking every time I hit the start button. Can anyone help me out at all? This has been a NIGHTMARE. Super appreciative for any help. Thanks.
