Here's My Videos
By rjsummer
By middlebrookgt
By Boss_Mare
Hi! I just purchased a 2018 Polaris Sportsman 450 AWD. The instrument cluster reveals 306 miles, ENG 75.5 hrs, and Service Due 83.4. Oil and coolant are clean and levels are good. Air filter is also clean. Everything shows the ATV is in excellent working order. But... every time I start it, the check engine light lights up (no code is displayed). I am worried the light may indicate something serious, but I can't figure out what. Any ideas/suggestions will greatly be appreciated.
By Tahj
I just added a 1999 Honda 300 Trx FW to my problems.
Indicator lights work, has spark, carb been cleaned, valves set. Cranks - no start. Is there any way to check the timing chain without pulling the valve cover and looking at the marks on the timing gear.
The timing chain is behind EVERYTHING in the right case.
Tahj
