I have a Polaris 250, 2 stroke. The oil pump drive gear disintegrated due to age It’s made of plastic. I ordered a top end kit, crank bearings, oil pump gear (steal)!
I had the cylinder bore 10 thou. Starts right up and runs great until it warms up. Then want to die at an idle and seem to run hot like it is running to lean. I brought up the needle on the slide to richen it up but it runs very rich. ( 2 stroke pop chug pop) Like they do when running rich. I wonder if the WSM piston is not expanding when hot or if the bore job was a poor job.
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
    • By Shorty51
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
