Hello everybody,
I am the owner of a 2005 Kingquad 700 with 10251 km (6370 miles). I bought this ATV one year ago. Since I have this ATV, I have a high oil consumption. 20 fl.OZ each 150 miles.
Therefore I decided to change the piston rings and also the valve seals. The ring clearance was out of tolerance.
I did not change the piston and the cylinder. The clearance of the new rings are in the tolerance.
After the change of the rings and seals the problem seems not to be solved. :aargh:
The oil consumption is still the same. :mad:
The problem is that the ATV is not smoking blue (like oil burning).
The sparkplug is coffe brown in the middle and black outside. The spark plug is completely dry.
The coolant has a normal colour. No oil inside.
There is no oil leak.
The airbox is dry.
The engine is starting and running normally!!!!
I change also the oil type: 10W40 -> 10W50
Where is the oil going? I am sure that the oil is burned but why is the ATV not smoking blue ??? With this high oil consumption, I expected that the ATV smokes blue or the engine wouldn t run properly.
My next step would be to change piston and cylinder....
I am confused and it would be helpful if somebody have a good idea.
Did you machine the cylinder sleeve when you changed the rings? If not the rings might not of seated correctly possibly leading to oil slipping past the rings and being burned. Im not familiar with this atv but i would assume its water cooled. Maybe you have a bad head gasket too
Sent from my SGH-T989 using Xparent Blue Tapatalk 2
    • By captnunu
      I have a 2007 kingquad 450 fuel injection. I try to start it with the hand crank and almost flip over the quad. I have taken the hand crank off and cleaned it but this did not fix the problem. I believe there is a decompression valve that is supposed to engage when pulling it over by hand. How can I check this?
    • By Zrach
      I wanted to share a successful workaround for a "no-spark" issue on a 2009 LT-A400.
      This is specifically for cases where the CDI has been diagnosed as faulty, but the age or condition of the machine makes the cost of a brand-new OEM unit hard to justify.
      Note: This modification compromises the factory “no-start” circuits.
      On some malfunctioning CDI units the internally damaged circuitry is only partial.
      Feeding full time power to the Parking Brake pin, the unit is triggered to bypass the internal fault and produce a healthy consistent output to the Ignition coil.
      The Modification
      See the second diagram attached below for the wiring specifics.
      The Result:
      The machine has clocked over 1,000km since this repair and is still running strong with no ignition dropouts.
      ⚠️ IMPORTANT SAFETY WARNING ⚠️
      Please be aware that this modification compromises the factory safety "no-start" circuits.
      The machine will now start in gear. The safety interlock involving the handbrake is no longer functional. The machine can move unexpectedly if the starter is pressed while in gear. Proceed at your own risk. If you sell the machine or let others ride it, ensure they are fully aware that these factory safety buffers have been removed.
      Faulty CDI Workaround.pdf
    • By middlebrookgt
