Hey all just got done rebuilding carb and have a problem. The carb is back to stock settings 1 1/2 out on Air screw and factory jets. My problem is now when its running its got a high idle. the needle slide is flush at bottom and the choke is working properly and the idle screw is backed out and not touching the slide but still have a high idle. I checked the boot from carb to engine and it has no leaks. I sprayed carb cleaner all around it and its not leaking no where
Can anyone help please im stumped
    • By toe420
      I got a couple yamaha moto 4 225cc quads. The guy gave me several old starters with them. I see kits are available to rebuild them but does anyone have tips or tricks for doing it? I haven't rebuild a starter before so im not sure what to look out for.
    • By colin james
      View File 2017-2019 sportsman 450/570 with eps factory service manual
      This  is the factory service manual for the 2017-2019 factory service manual for the sportsman 450/570 with electronic power steering
      Submitter colin james Submitted 09/06/2018 Category Polaris ATV
    • By ButchM
    • By dkgg5755
    • By Jason39
      I’m having a issue with my choke when its on it runs fine when I cut the choke off the atv cuts off went to take the carburetor off and saw the choke plunger broke at the nut to screw it in could this be my issue? Do I just need to buy a plunger kit and put it on? I took the carburetor off and cleaned both jets anyway just to make sure and it’s still having issues staying on
