Polaris Sportsman 500 - Replacing Rear CV Axle
By
jeffreyscott, in Polaris ATV Forum
Similar Tagged Content
By Aaron Wilson
My 1996 Yamaha Kodiak 400 has a cracked CV Axle boot and the axle wiggles back and fourth if you pull on it. It also clunks if you go from forward to reverse fast with the tires turned hard one way or the other. Im thinking a new axle will solve the problem. Can you guys walk me through the steps of replacing the CV Axle, I have never done anything like this.
By Guest Fox300exchic
If you know you're going to be bashing your quad's axle over rocks and rough terrain, tape it up. Take a roll of electrical tape and generously wrap the axle from the swingarm out to the hubs. Standard electrical tape will work, but the heavy-duty thick stuff is even better. When you are done bashing you bikr though the nasty terrain, you can cut the tape off and still have that showroom shine for your next out to the dunes, where you don't have to worry about getting dings!
Quad off-road magazine
By Alan Callison
Hello boys and girls!:howdy:I need a little help if ya dont mind.I need to replace the rear axle bearings on my 400 but Im going at this blind having never done it before. Ive looked it up in the repair manual but it doesn't give any specific steps on how to do it. I've got the left rear brakes off already as I was replacing the shoes anyway. Can somebody give me a rundown on what Ive gotta do please?I know I need to pull the right wheel off just havent done that yet. Do I need to take anything apart in the final drive or elsewhere in order to yank the axle out for instance? Which side does the axle come out from,L or R? Any details I need to know will be greatly appreciated.Thanks ya'll!
By Alan Callison
OK everybody,I need some help here please. My 4 wheeler has got a bad wheel bearing I discovered while starting a brake job. Its on the left side. I've never done one and I need some knowledge how to go about it. Am I to understand I need to pull the whole axle out to do it. I've done it once on a car about 30 years ago,lol. I keep looking around for a repair manual but they're hard to find without having to buy it. I looked here on this site but apparently Im too junior a member to be able to download one right now.Bummer! One other question if I may.When I pulled the drum off the spindle a torrent of water poured out,the brake shoes were covered in mud along with everything else. I mean the drum had alot of water in it. The shoes were so locked up after I removed the springs I tried to rotate one of the shoes and it wasn't easy at all. I noticed whoever had the machine before myself had laid a bead of RTV around the back plate but apparently it didn't work. Isn't there some kind of gasket for this purpose. I saw it calls for a dust shield but surely this wont keep the brakes dry or will it. Thanks everybody.
By Darryl Traina
This bike has a straight axle that is moving horizontally in the housing in both directions about 2 inches. Has anyone had the same issue if so what did it take to repair it?
Thanks..
Darryl
Similar Topics
By leewhite
hey guys , I have a question , me and a buddy acquired a cottage and was given a Honda Rancher with it . I can seem to find solid info on the year or model , that being said I am not a expert and dont have acces to the ATV but I do have a picture if it can help you guys. It seems like a 2001 but I'm not sure
thanks
By Maddie3142005
Bet you've never seen a Tonneau cover that can hold 2 - 4-wheelers on top of it. This is a home-made heavy duty fiberglass truck bed cover that was used on an 2000 F-350 with an 8' bed. We have used it hundreds of times but are getting out of the 4-wheeling fun. You can waterproof with a rubber seal, not included. This leaves the area under the cover open for all your gear and firewood. It is white and in great shape. 4-wheelers NOT included.
By richard fischer
I have a new 2020 cforce 600 touring and read how smooth the shifting was on it. Mine however, sticks in gear quite often and only after moving the bike around does it finally shift. I use the brakes before shifting as it says but that doesn't seem to affect it either way. Anyone have this issue? Is there an adjustment on the linkage perhaps? Any suggestions are appreciated. The machine is new with about 10 miles on it.
By emoyer105
I have a Yamaha Timberwolf 250 2x4 that I purchased a while ago as a project. I fixed it up to where everything was working great in my opinion, however when I showed it to a potential buyer he complained about a vibration from the rear drive shaft. (Which I ridiculous seeing as he tried to wheelie it before that) Anyways I took the rear diff apart and found most of the seals and bearings where bad. So I bought a kit off of amazon only to find that it doesn’t have all of the bearings and seals. After finding that I decided to try to find a used good condition replacement but they’re all to expensive for me so is there a better alternative for me, or can someone point me in the right direction to get the rest of the parts?
By vonda flynn
I need help please. This is all new to myself & my husband. We have gotten 2 used fourwheelers so we can ride with our kids (kids have go carts). One of the 4wheelers is a 1998 Suzuki Quadrunner 500 4x4. It has rearend trouble.
We are having a difficult time finding new or used parts, & no luck with aftermarket parts.
Hoping someone here can help. We were told by Suzuki dealership that some Artic Cat parts will interchange, but he wasnt sure which ones & said there are companies that produce aftermarket parts, but wasn't any help there either.
Any help or information is greatly appreciated.... Thank you.
