Hello,
I have aquired this 4 wheeler from my Dad who is moving to a town home. I will be mostly using if for plowing snow but there will be an occational trip though the woods with the kids. When plowing a pass and stoping the 4 wheeler will kill. It will start up and keep going if I keep my thumb on the throttle a little.
My next issue is the other day I took my daughter for a ride on level ground. When I turned around the 4 wheeler sputtered so I gave it more gas, when I looked behind me there was a big cloud of white thick smoke. Not sure where this came from. I would like to try and fix this myself since the repair cost at a shop I'm guessing would be expensive. This is a manual transmission with a foot pedal shift. Would it matter if I started in 2nd gear? Any help anyone can give is appreciated. I'm not affraid to take it apart and put it back together I just need to know where I should start.
Thanks,
DB
If you have to keep your thumb on the throttle to restart it, it's running rich (flooding).
The 2 leading causes for what you describe are: 1. The "choke" cable is pulled out of it's plastic socket on the carb. Remove the seat and look on the right side about half way back. There are 2 control cables going into the carb. The "choke" cable goes in to a plastic nut on the side of the carb. Make sure it is lined up squarely and fully seated into the carb. 2. The needle valve or float is bad. You'll have to remove and disassemble the carb to fix it. Before attempting removal I'd strongly suggest you download the service manual for your ATV. I also found the 96-98 Polaris manual very helpful with these carbs. They use the same ones.
oxidized_black is a great help finding downloads.
onlinecycleparts.com has the best prices and flat rate shipping ($7).
      Pretty cool modification for all you 3-wheeler enthusiasts!
      CboysTV - "In today’s video, we build an electric 3 wheeler out of an E-bike pro. We also take our sandrail mudding and later try and find the love of our friend Gavins life by taking him speed dating."
    • By dvs1961
    • By Paul Leatherman
      Hey all,
      I am in search of a rear collar/hub part #2HT-25383-00-00 for my sons 4-wheeler. Of course it is very hard to find.
      Does anyone have any idea where i might find or would a cross over from a different model work?
      Thanks,
      Paul
    • By Dezertrider65
      I just have a question.
      If I was to buy 3 Wheeler from a private party say a 1985 Honda 350 can I get it made street legal and if not can I still ride it out in the Arizona deserts?
    • By autocustomizer76
      Hey all got a Kawasaki 300 that's seen better days I'm looking to get running.  But first, I'm working on a Honda 350 ES and mainly needing where are you all finding quality parts at good prices.  Atvs are really hot items around here right now and most of the folks wanting and needing them are not familiar with working on them.  I'm looking to find a good resource for information and if it works out well pass this group along to the folks I help to get them in the know how to get the most out of their machines.  Thanks in advance.
