Similar Tagged Content
By Ajmboy
This is more of an informational fix I wanted to share..
My Grizzly has been getting harder and harder to shift this winter and today was completely stuck and I needed to plow the few inches that came down this morning. First thought...oh no, tranny...but it’s winter and maybe it’s iced up. I pulled off the plastic to see what was going on and indeed I did find the drain tube iced up.
I took the blow dryer out and de-iced it. Quick fix, I never really thought about the shifter drain tube icing up before, shifts like new!
FA04AC3B-4FB0-4764-AFD9-1492F5CC790B.MOV
By Matt Dyche
Can anyone give me guidance on my issue. I have a 02 Grizzly 660 and replaced the wet clutch, primary shaft, one way bearing. Today I was riding since I tested and was driving about 20-25 mph and all of a sudden the tires locked up, heard a screeching sound, and engine died. Didn’t have a clue what was going on, decided to try and restart, engine turned over normal but engine hesitated slightly, started and had to assist with the throttle. It seemed to do this for a minute then seemed to straighten out. Got home, pull clutch cover and test drove to witness clutch operation and everything looks and sounds perfect. Could not duplicate. Please help.
By Guest Fox300exchic
If we had a dollar for every time the question “Which is really faster, the 700 or the 450?” shows up in our inbox, mailbox, or voicemail, we’d be putting this magazine together from a bungalow on a barely inhabited tropical isle named Quadhama.
http://www.quadmagazine.com/quad/features/article/0,24942,1603755,00.html
By dglover1226
I have a 01 raptor and recently had to bore it out to a 686 because it sucked in a bunch of sand. Now I have no torque or power in the first third of the throttle. I am hoping that someone else knows what is going on with it
Similar Topics
By Randel1
I'm having a problem getting a CDI unit that works. The parts list calls for a 4XE-85540-00-00 CDI unit. The one currently on the ATV works but there seems to be a problem with the spark advance curve. It will idle fine an rev. to about 1.5K then starts bogging down sputtering, popping and basically running poorly. If you can get it above 2200 RPM it runs better. I have ordered and returned about 5 replacement modules that will not work at all. The unit currently on the bike has no part numbers or identification other than a Mitisibuchi logo. I am wondering if anyone else has experienced similar problems with replacement CDI's and if so what is the fix? So far I have not found a replacement CDI that will supply an pulse to the Ignition coil.
By texaskaw
fighting this thing for a month now.No spark at plug.
New ignition coil,pick up coil,stator,reg/rectifier,all new wiring.Started it up today rode for an hour shut it off.Tried to start later wont start.pulled plug wire it firing a blue spark while starter button is pressed.Tried new plug no change. It stared a couple times an ran for few seconds then died.Will CDI act this way? The reg/rectifier get pretty hot is this normal?
By Tiffany Rowland
I am working on a Honda sportrax I just got my daughter for get birthday and the reverse and neutral light are not working. When I traced the wire down I saw that it wasn't plugged in but I don't see where it is supposed to connect. Does any one have a general idea of where I should look?
By Michael Thornton
Why does the 2001 grizzly not have com bearings or something to protect the head.
By JacobSlabach
i know this isnt an atv but same type of thing. I have a riding mower im fixing and selling for my aunt and it has a dead battery. i jumped it off my atv and when i turn the key nothing at all happens. i tried jumping the relay still nothing. this is with the seat down. you wouldnt think this mower would have issues as its a top-of-the-line brand and almost brand new (aunt found it for a good price, still got tits on tires, just sat for a couple months in a mechanic shop
