Not sure but I think its using oil. The engine always does this no matter how long it runs. The engine was running about 30 minutes in this video.
[ame]
[/ame]
The exhaust will blow out carbon also when reved up.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
are you going thru a noticeable amount of oil? have you checked the valves yet?
Valves are adjusted. As for a noticeable amount no. But the plug gets fouled a lot also.
I was using some seafoam cleaner in the fuel also. This could maybe ruin the plug i guess. But the white smoke is my main issue i guess.
I am seeing seafoam can cause all the smoke.
Edited by DerkS
what does the smoke smell like? oil or fuel? how does your oil look (milky?) and what weight are you using? how are the vent lines from the crankcase to the air filter box? is there oil in the filter box?
Smells like fuel. Oil looks fine. It it 20-50w with some Lucas oil additive. Vent lines are fine. No oil in air box and filter is clear.
    • By marlon smith
    • By digrig
      Hey everyone,
    • By mikeexplorer
    • By Ironworker709
      I have Grizzly 700 that has been pretty much totaled out in a bad accident, but it will still run and drive good...
      Will this engine swap into any of the Yamaha UTV's like thr rhino and Viking 700's?
      Was just going to sell it as is for a engine for someone who needs one pretty cheap..but been thinking about getting a UTV for the family and maybe find one with a blown engine cheap and swap it out
      I already an excellent shape 2001 Big Bear 400 4x4 for us..but kinda been looking for a good used UTV for us and the grandkids on our property to play with
      Not sure of the year..i can't remember what year it was when i picked it up for a buddy a few years ago..he went to jail after he totaled this thing and told me to pick up a few things at his house he was renting and just keep them for myself since he owed me a bunch of money before the landlord sent them to the dump...
      The first picture is when i went and picked it up for him..second is how it is now..frame is all twisted up and plastics are fubarred..going to sell the rims and tires.they stick out way too wide on my Big Bear
    • By goatman
      quad is a new to me freebie, pulled carb and cleaned it. got it running and idling nice but mid throttle it craps out and will go down to almost a stall, i release throttle and it just sits there idling away happy as a pig in poop. i was thinking fuel restriction then i noticed the exhaust glowing red in the sunlight. so its running lean
