Here's one on ebay for $100. Not all years interchange, but if you go to cheapcycleparts.com and look up the part number for yours and the one for sale, it will tell you if they are the same part number and will therefore interchange. If that one for $100 fit, IMHO grab it. They don't come up real often. Usually by the time you need one, so does every other one made that year unless it was garage kept and babied. In which case they probably aren't parting it out, but still driving it.
Most years the KingQuad and LT-4WD (or 250 Quadrunner 4x4) will use the same muffler.
http://www.ebay.com/itm/98-Suzuki-LT-F250W-Exhaust-Muffler-/271116939185?hash=item3f1fd42fb1&item=271116939185&pt=Motors_ATV_Parts_Accessories&vxp=mtr
Edited by catcandu
forgot link
    • By sunn
      Have a high heat issue on the right side panel on my 2021 cforce 400, as complained about by the wife.
      My heat gun shows after 15 minute ride in ambient 91 deg temps;  690 degrees on front end of muffler close to entry pipe and 375 on exit side of muffler.  The right side plastic (where wife's leg would touch) was showing 175 degrees.  This is rediculous!.
      As I understand the muffler has a built in catalytic converter which obviously kicks off high heat particularly at front end of muffler, but the heat is atrocious.
      What is everyone doing about this problem?  Is there a replacement muffler to eliminate this issue?
    • By n4cer26
      Hi!  The wife and I are planning to head to Indian River this fall for a couple days to ride the ATV trails.  Looking for a good place to stay that is close to the trails so we can ride from the lodging location. Any recommendations or tips on Indian River?  Thanks a million!
    • By n4cer26
    • By TravisCr
    • By p5200
      I'm wanting to try and get the machine on blocks. I just want to verify my AWD is working. How do most of you go about doing this. I want to be safe since it will be in gear with hopefully, all wheels spinning. Thanks! 🙂
