just got this boyou 300 don't know the year and need to find were the numbers are plus the spark is real weak and one other thing can't see any oil in the crank case fill hole and was wondering how to tell when its full. I did download the manual for this but not much info for what I need.
So help
Mike aka the pirate:aargh:
I have new plug in it but still weak spark.I have had snowmobiles but the motor on was easy to get to. I know some about power packs. I did down load the manual that was on here but does not give much on trouble shoting.
So if someone on here can give me some ideas on were to start and what to look for maybe I can get some good spark
Thank
Mike aka the pirate
Aw but if you niticed I sign my name the pirate That means I have one leg to work with. Plus to top it off I'm 72 years old. I have had snowmobiles old ones for 20 years and my main hobby is old outboard motors. Some of the newer outboard motor have had the power packs on them
Noiw these Quad runners are something new to me. So if I seen a little slow its just that these are new to me.
And I will take any help I can get
Mike aka the pirate:biggrin:
it said there might be a number off, but this is what it said it was ....
if you can shine a trouble light there and look with a magnifying glass, you'll probably get it spot on.
but i think you have all the important numbers there for sure
Edited by oxidized_black
  • 5 years later...
I had same problem mine will run like a top shut it off go to start and nothing won't start so I put new coil and starts better but still not right everything I've read along the way points to stator if u figure it out give me a holler
  • 5 weeks later...
So help
there is a sight glass with 2 marks in the casing indicating high and low levels below the fill cap. for the weak spark i have found a weak battery when using the starter will produce  a weak spark. but using the pull rope produced a strong spark.
    • By cavry
      Cavry
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By oztrax
      MAX 4 6X6 2008
