By Adamb2025
By TomJulio
I recently noticed my Fourtrax 2WD has 4WD wheels installed on the front. The back spacing is significantly different than 2WD wheels and they are almost touching the strut springs and the tires actually do touch the springs.. So far, no luck locating 2WD wheels to correct this issue.
By Olchap
Thank you,
Olchap
By Autokill83
Good Day, just bought a 1988 Big Bear 350 and am missing the bumper - will a bumper from a 93 with the holes in the front fit up directly? Please see the attached pictures of the bumper for reference. any assistance would be appreciated. Thanx !
