I bought this 250s from a friend, (along with a sweet ATC 70), but I am having all kinds of trouble getting this thing to run.
I rebuilt the carb, have strong spark and it is getting fuel. Seems to have great compression. I was able to push start it once or twice but my neighbor couldn't keep it running and trying to push start it destroyed the teeth of of both sprockets. Best I can do with the kickstart is to get a backfire when I drip a little gas in the cylinder.
Anybody have a good link to a service manual? I think the next thing to do would be to check the timing?? Not sure how as I don't see any inspection plugs anywhere on the cases.
Any input/help is greatly appreciated.
Thanks for the links!
I suspect the valves need adjusted and the timing may be off. I did have it started though(well my neighbor did when I was towing it behind my wheeler - but he kept accidentally letting go of the clutch while in gear and couldn't keep it running) and it seemed to revv up ok.
But now with the manuals I will have a little more guidance in getting the valves and timing set then I can go from there.
Create an account
Register a new account
Sign in
Sign In Now
    • By ruslan1o1
      Hey everyone looking for a suggestion of where i can start looking. But first I'd like to explain what happened. Took the bike this morning got it started in 6 degrees celsius in 6-7 kicks? No choke. Drove 6km and when shifted to next gear bike decided to just shut off, stopped checked everything out seemed good, started first kick and on i went, drove maybe another 2km bike did same thing but this time it took me 10-15 kicks to get it started, on the third time after a kilometer decided not to start at all. Kicked it like a 450 a couple hundred times, nothing. So far checked gas is good, bypassed fuel filter and on/off valve to eliminate that problem, hot wired the kill switch in case something got corroded there. Nothing. Any suggestions would be welcomed. (Heard valve adjustment are a must do?)
    • By Bobbles
      New to the forum here, hoping someone can help. I have replaced the cdi, coil and sparkplug yet still no spark. The measurements for the igniter and stator are what they are supposed to be, the kill switch is working as it should, the neutral light is working as well. Any ideas where else to look before i start trying to pull it apart for the stator and igniter?
    • By darklord19991
      We rebuilt the engine put wiring back together it ran before but now it won’t and has a weak spark we have been trying to figure it out for about a week and still nothing changes does anyone have any help on what it might be?
    • By Dumass
