Similar Tagged Content
By Alois Specht
Hi there , have a KAZUMA 500 JAGUAR the rear diff is permanently locked , how can I get it out of lock just about tried everything I think, ?? . Thank you your help is appreciated.
By mrfartsalot
i have a 2001 suzuki quadmaster 500 4x4 that the primary cvt clutch is rusted on any ideas on how to get it off i want to try to reuse it if possible.
By Paul Maple
I have a 1999 Sportsman 500, it was running fine, than started to lose power in the winter, I adjusted the idle screw and away I went, than a few weeks ago it died, I have found that i am flooding the engine, compression was at 70PSI and due to the compression release mech. i assume i am good as it compared to the same PSI on a 2000 sportsman 500 i have. i cannot start the atv unless i go full throttle and it starts an runs for about 30 sec than dies, again it is flooded. i ordered a new carb off ebay as i could get one for around $40. put that in same issue, i have checked the timing, (good), valves out of adjustment i adjusted to .006 still same issue, i have found the exhaust lobe and rocker arm to have some wear, i have ordered new ones, but am looking for any other input in this area as well. would the exhaust cam and rocker arm cause the engine to flood? i have used a bore scope and the piston liner has good cross hatching still? any input would be great.
By colin james
View File 1996-2000 Polaris Sportsman 335/500 Service Manual
This is the factory service manual for the polaris sportsman 335 & 500.
You can download the section you need or download all of the chapters for the complete manual
Submitter colin james Submitted 10/19/2018 Category Polaris ATV
By colin james
Similar Topics
By Brennon Heflin
So I bought a 2000 quad runner 250. I'm having some issues an wondering what it could be I replaced the pet cock valve an the fuel filter an pump inside tank I also put a voltage regulator on it. The problem I'm having is that when u give it half or more throttle it bogs down an loses power what could it be the bike is almost like new an cant figure it out any help would be great
By Stephanie Webb
I have a 2000 500 quadmaster lta an just rebuild the gear box an my high gear is like nuetral will not move but all other gears move nothing looks broke just need some help cant figure out what gear that would be or if it could be the shifter fork
By NoahJakavi
Hello i have a linhai 300 of the 2004+- era. I had a cluch problem so we changed it. After changing it has a hard time to start going. When you pop it into gear and press the gas it barely drives but when it starts going about 20km/h it start driving well the acceleration is normal and everything do you have any idea of what could be the problem
By smitht18
Looking for the rectifier. Most bikes have near magneto. It appears the KQ has it in front.
Can someone tell me exactly where it is?
Bike not charging and magneto checks out ok
By Hunter19
How are you doing guys I just joined I have a 1998 Suzuki King quad I’m having problems with high RPMs the ATV idols perfectly but soon as a throttle up it doesn’t stall but it just bogs down it has no power any suggestions thanks
