    • By Arizona
      Just recently bought a dead 06 Eiger, Can someone post or send me a wiring diagram for it:?
      Need to check all wires, no power in most places, Cant seem to read the ones from online manual,
      too blury and cant tell wire color. Just too small. Thanks Az
    • By Peisledder
      Hello, can someone help me? I have a MAP error code 102-3, and the MAP has 4 wires: light blue, orange, purple, yellow. I’m getting different results on what the wires are. I don’t have wiring diagram. Can someone confirm which is ground, 5v, MAP, and Temperature?
    • By davefrombc
      I added a pdf of  the wiring of the various connectors used in vehicle socket  and trailer plug wiring to the  "Other ATV files"  section in downloads.
    • By mikeexplorer
      While wiring in a set of reverse lights I discovered the diagram is wrong concerning the shift position switch.  It is shown as LHNRP but its backwards, PRNHL
      L/W and R/Y wires close on reverse, not L/W and GR/G. Found out the hard way and had to re-do it.
      Diagram is Alterra 600 LTD
    • By neilroy87
