Similar Tagged Content
By ATVNetwork
Fort Worth, TX- February 24, 2012 – QuadBoss is proud to introduce a new line of High Performance Radiator Cooling fans as well as OEM Replacement Cooling Fans. QuadBoss’ new High Performance Cooling Fan will make your quad run cooler and last longer. The increased air flow created by QuadBoss radiator cooling fans will help prevent overheating often caused by towing heavy loads or crawling through deep mud. The high-quality, sealed motor provides optimal protection from the elements and will easily mount to your radiator. The High Performance Radiator Cooling Fan meets or exceeds OEM specifications and comes with a 6 month manufacturer’s warranty. Endurance tested to insure a long life, these cooling fans provide the reliability you need to protect your quad.
Available on Amazon
To order QuadBoss products, contact your local authorized Tucker Rocky Dealer or visit QuadBoss’s website at www.QuadBoss.com to find an Authorized Dealer near you. You can also follow the latest news about QuadBoss on Facebook at www.facebook.com/quadboss. For product questions call 877-847-1558 or email at [email protected]
By davidwestfall
hey I'm dave westfall I'm new I just became an official member of this site a few minutes ago. Ive been crazy about quads and bikes since I was about 3 and ive always done my home work on them figuratively speaking. I would say for comparison to the common man that I am pretty knowledgeable about them. its been my passion about most of my life. I love talking about quads and bikes so if anyone out there would like to talk with me about mechanical subjects or about person experiences while riding or just shoot the breeze please feel free to chat with me. I'm looking forward to it.
By casizemore
I am going crazy trying to figure this one out. Recently snorkeled 700efi is overheating but I am inclined to think that the problem is not related to the snorkeling. My fan is no longer coming on. I checked the fuse and also the diode marked fan in the fuse box and found both to be OK. I checked the fan to make sure that it is working under normal conditions so I powered it directly from a battery and it works fine. I checked the continuity of the sensor and it works as well. Hooking a positive from an outside battery source to it. Once the temp got high enough the fan came on. I downloaded the wiring diagram from the forum and it indicates a diode in-line with the ground. Does anyone have experience with this?
By terrilarry
Went for a ride today with some new tires and my bike is pretty dirty. I don't have a high temp light, but when I turn my key to on, my fan runs even with the engine off. What can cause this?
Similar Topics
By ATVNetwork
news A powerful trail machine ready to tackle the hardest adventures.
Polaris unveiled the 2021 Sportsman 850 Trail Edition ATV with factory-equipped enhancements to tackle the roughest terrain. View the full article
By jung4g
The quad has done this off and on, almost since new, but it's gotten worse this year. Sometimes if I freshly charge the battery, it'll work fine, others times that won't matter. Turning the key to on it sounds like it's connecting as I go to the start position, slightly before the full turn, but it's not like there is just a sweet spot to find, it's totally erratic.
Now the battery is basically dead so I put a new, slightly bigger AGM battery in today to replace the factory one with all of 800 miles on it, but those have lots of plowing hours included.
I was able to get it started once, but it still went into limp mode after just a few moments of driving it (that's another topic), so I put it back in the garage and started probing around. Now it doesn't even try to turn over.
Is an ignition switch, the $18 shipped aftermarket variety on Amazon worth a shot? Or should I go straight for the starter? The new switch may not come for over a week, so I hate to just put my hopes in that if I'm missing something obvious. Fuses are good, so it's not something super obvious.
By Budman
After purchasing a lightly used 2018 570SP (300 miles on it) I noticed that the display was flashing on and off. I remember reading awhile back that this was a common problem on the 18 model. I can't remember what the fix is. It also turns over slow even though the battery is charged. Anybody know what the fix is on this issue?
Budman
By Hodadical
I've inherited a 1995 Lakota 300... it has the knob in the center of the handbar to twist to go into reverse, but I've notice when downshifting, you don't have to have the knob turned, it will shift right past neutral and into reverse which is a little dicey if not all the way stopped. I followed the linkage back and twisting the knob seems to actuate the lever on the outside of the trans, the internals just don't seem to care about this.
What is the likely problem and how back is it to get to? I've never been inside of one of these transmissions.
TIA,
-Rob
By cody75
2016 sportsman 450ho cranks. Good spark, removed injector getting fuel no check engine light no start
